Baja Designs: General Discussion Thread - GEN 2
Speeddeacon
NC
“Tons of new product” For those of us who can’t be at SEMA, please tell us what other new products do you have besides the LP4??
Speeddeacon
NC
Regarding the S1 mounted to the XL brackets on the A pillar, is there any clearance issue with the antenna?
Nick@Apollo-Optics
Houston, TX
I installed my S8 bar behind my grille this morning (I took a big risk and got up an hour early before going away for the day with the wife) the install went great, but the only thing that remains is tapping into the marker lights for the backlight power... Where’s the best spot to tap into that?
I always tap into the passenger's side front side marker light on the fender flare. You can trace the wires directly back from that light, pull the fender liner out of the way, and then use a T-tap.
Baja Designs
Baja Designs
There will most likely be clearance issues with the antenna. I personally switched for a stubby antenna
