Baja Designs: General Discussion Thread - GEN 2
brettmess24
If you purchase multiple items that apply, you'll get a check for everything.
S2 Pro, Pair = $50 rebate
S8 20" = $75 rebate
Total Rebate = $125
You are not required to place multiple orders.
Saweeeeet!!!!! We need to wait till Monday to order?
raptor36
Is this for the previous ONYX6 or the ONYX6 plus?
4x4TruckLEDs.com
Since orders have to be placed between Monday, November 19th through Monday, November 26th, via an authorized Baja Designs dealer (or direct) it would be on the new OnX6+ bars. OnX6+ bars is what ship now adays.
joegie
North San Diego
planning on running the 20" onx6+ with the new add no cut front bumper, I see that the light requires 16.6a but the upfitter only has 15a. if I use harness #640122, I believe this comes with a relay, would this be sufficient to power the light or would the fuse pop? I plan to run this on switch #1. thanks!
Baja Designs
Baja Designs
Correct - you need to wait until Monday 11/19 to qualify for the start of the rebate.
This is for the OnX6+ and OnX6 Racer Edition. The standard OnX6 is no longer available for purchase.
With a relay, you'll be fine to run on a lower rated switch. The relay will take most of the load off of the switch. This harness is less expensive and would still get the job done:
https://www.bajadesigns.com/products/onx6-s8-xl-pro-sport-harness-2-light-max-150-watts.asp
Baja Designs
www.bajadesigns.com
joegie
North San Diego
Baja Designs
Baja Designs
SAE Fog Lights - COMING 2019
Who's ready?
More details will be posted in the month of December :)
