Baja Designs: General Discussion Thread - GEN 2
raptor36
Overland Expo West - 5/18-5/20
Overland Expo West in Flagstaff, AZ is coming this week! Just 5 days away. We will be at the show so there will be a delay in forum response. Stop on by the Baja Designs (BD) booth for product info and to check out the latest and greatest from BD. We will be having show specials through SDHQ. Give them a shout for a deal on Baja Designs products!
www.bajadesigns.com
Standing by to hear the “latest and greatest from BD.” :)
rlevy
Unlimited Kit
Should I be able to hook the squadrons up to switch number 4; 10 amp. I tried and the relay blew immediatley. I rewired to switch 2 and seems to be fine. Thoughts? Thanks
Baja Designs
Baja Designs
The 4 Squadrons total 11.6Amps which would be why the 10A fuse wasn't quite enough. If I remember correctly the Switch 1 & 2 are both 15Amps which shouldn't blow with the 4 lights only. Is it possible you accidentally hooked them up to a lower amp rated circuit?
- Baja Designs
www.bajadesigns.com
rlevy
That makes sense I should have read the other side of the box. One other question. Is there a disadvantage to grounding directly to the battery or is it recommended to ground to chassis?
Baja Designs
Baja Designs
Either will certainly work. Grounding directly to the battery will guarantee a good connection, but most chassis grounds work
-Bailey, Baja Designs
www.bajadesigns.com
FullAuto
This pic just sold me on the amber wide cornering.
I'm going to do a similar set up on my SVC bumper.
Be advised I have a set of the pros combo in white and a set in wide cornering in amber. Just show your friend this pic.
---------- Post added at 10:00 AM ---------- Previous post was at 09:57 AM ----------
Also loving my new rear baja lights! Pair of Squadron Sports and a RTL-S
reaper1441
Added a 30 inch onx6Hi to my 2 XL80s. Pretty good combo.
@FullAuto svc doesnt have a way to mount a baja designs bar to their bumpers yet. I had to weld my own. They pretty much make you buy a KC or visions X with how the bumper is made.
