HighlineRaptor
Has anyone else had this noise happen to their truck? I believe it may be a bearing on the way out
View attachment low IMG_1014.mov
I know that video is not how you check bearings. but there was a noise and I wanted to see if it could be replicated. I did check bearings the correct way, just not on video. The sound is focused at the center of the axle hub, just need to figure out if this is a bad noise or just a noise. I have a 9 hour drive, towing my Mustang to the Sturgis Mustang rally coming up, and I want to make sure the truck will be ok for the drive.you are killing me. That is not bearing noise. That is not how you check a bearing. I am not sure what the noise is, but it ain't a bearing.
I get people/customers who video me noises, and not one single time has it worked.
I will look at that. Didn't event think of that being a possibility. Thanks.The isolators on the leafs???
