B&O Stereo upgrade
Dubai
Hey everyone! Just purchased my 2018 Raptor and have been reading the audio threads after not being pleased with the factory system. After seeings everyones post this is what I have come up with. What are your thoughts? Anything you would add/removed or change?
Nav TV A2B
JL Audio RD 900/5 amp
MTI single 10" box & amp mounting plate
JL Audio 10TW3 4ohm 10 inch sub
JL Audio Evolution C2 Speaker Series C2-650 6.5-inch Component Kit
JL Audio C1 Speaker Series C1-650x 6.5-inch Coaxial Kit
Stinger 4-gauge wire kit
Should I also purchase the JL Audio TwK-88?
Did you price this all up yet? How much are you looking at?
pbtjrlmrt
Oregon
Nav TV A2B
All good stuff and yes definitely get the TWK. Ignorant people think that the DSP is just for coloring the sound. I have almost the same setup and the speakers are set to reference for the most part. The DSP will allow you to set speaker timing and other stuff to get the best sound possible. You can't dial it in without the DSP and if you're spending the money why not do it right. I also went with 2 10s behind the rear seat....I really think it's necessary. They had to build a very custom fiberglass box but it sounds fantastic and I retained all my floor space.
double dee
double dee
Phoenix, AZ
about $2,500 if I install it myself
Did you put your amp rack under the seat in the storage box? I guess my reasoning for one 10" was a little cost saving and being able to put the amp rack behind the seat as well to save space
melvimbe
Well sure, but there are people who know very well what it is and how it's used and feel it's unnecessary for a truck environment.
My amp is under the driver's seat.
double dee
double dee
Phoenix, AZ
It looks like most recommend to go with two 10" subs and dsp.
Any benefit from having the amp/dsp seperate or would a JL amp w/ built in dsp be the same. I started looking at JL Audio VX1000/5i 1000w. It's not much more.
pbtjrlmrt
Oregon
Everything, dual subs, Zen A2B, TWK88 and the HD900 is mounted behind the seat. Hard to tell from the pic but it's one contiguous box. The zen and TWK are mounted where the stock amp used to be. The DRC knob for controlling bass output is in the consol under the heater controls.
pbtjrlmrt
Oregon
If that's the case then you don't care about centering the sound? Or do you use the fade balance controls on your head unit? Do you use the bass control on your head unit or just don't care about the base unit and balancing out the subs with the rest of the system? Necessary is a subjective word in this case but you can't actually dian in the system without a DSP. That may be good enough for some but for the few hundred bucks involved seems like a waste to not do it right.
melvimbe
pbtjrlmrt, I was not referring to myself, but to other people, as I stated. I do have a DSP, and I have a basic understanding of what they do for a system. However, can't claim to have listened to systems side by side and be say that the DSP makes a noticeable significant difference. I have not even gone in and messed with the configuration myself yet, as I am happy with what the installer did.
At the same time, there are other who know what they are talking about (not ignorant) who don't feel like a DSP is worth it in the truck. As you stated, necessary is subjective, and therfore, disagreeing with you can be explained by something other than ignorance.
goblues38
STL
My thoughts on DSP are this......I have been doing high end car audio and home theater since the late 1980's. Longer then some people have been alive (sadly).
In a car environment...it is absolutely correct that speaker placement is not ideal. woofers and tweeters many times are off axis from each other causing frequencies to arrive at your ear unequal times. So an electronic DSP can help here. But what also helps is understanding how frequencies work. The lower the frequency, the less it is impacted by frequency localization (where you can pin point its direction). It is why you can stick a sub in the corner of a room and no one know where it is.
The critical component in time and spacial alignment becomes more apparent on mid to high frequencies. In the front of a car, this is accounted for by where the tweeters are placed, high on the A pillars. Note, in our trucks, they are fired in the direction of the windshield. This helps improve the front sound stage (dash is the stage) and imparts a natural time delay for those frequencies (which move faster then mids and lows) and allows them to hit your ears in alignment with the door woofers.
Yes, the driver is sitting stage left....but in a concert hall if you are sitting in the left orchestra box, are they going to give you headphones with a fancy DSP to make your seat electronically become center stage? No. Part of the beauty of music and a well produced sound stage is some sounds are more localized left or right.
In a car you have balance and fade, speaker gain, treble, mid, and high control, and the EQ built into your iphone or spotify account. There is plenty of adjustabillity for one to dial in the sound for that vehicle. This is on top of correctly installed speakers.
In a home environment most rooms are very boxy at 10-20x larger then the space in a car, with harsh surfaces on floors and big walls that bounce sound all over the place. A DSP can correct many of these issues. Time alignment is more critical when you are 15 feet from your tweeter, not 3 feet.
But in a home, you can correct many of these issues with proper speaker placement, wall treatments, and other soft materials.
My home theater at home is state of the art Denon Dolby Atmos in a 7.4.2 configuration (7 surrounds, 4 ceiling, 2 subs). I have it dialed in with Denon's Audyssey DSP. But 90% of the time, I go direct (no dsp) because it sounds better to me without the electronic compensation. My room is prepped to care for many of the things DSP was created to correct. i want to hear my speakers reproduce what was recorded, not some lab technicians algorithm.
The point of all this rant is.......There is no magic electronic gizmo that will make a stereo sound good. nothing is more important then proper system design, and installation. yes, DSP has its place and benefits. But to discount a non DSP system as trash, or someone who does not use one as ignorant is just false, and shows who the real amateurs are.
