GEN 2 AWE OFG Exhaust Question
Raptor911
Ashburn, VA
For those running the OFG system, when you removed the OEM tailpipes, did it look exactly like the OFG tailpipes?
I am asking as I have the corsa system and I was wondering if I could use the cosra tailpipes with the AWE 1FG.
I hope my question makes sense.
Rob O
PNW
What do you mean, did it look exactly like the OEM tail pipes?
BIGDJE
OC, CALI
i got the 0FG full system.i have pics but i did not do install see if pics help you
the 5in tip i just put on myself to take pic it was not all the way on. i cant install tips until after bumper goes back on
BIGDJE
OC, CALI
one more better pic of tip. OMG they are crazy huge and very nice quality
Rob O
PNW
Do the AWE tail pipes have the same length and bend as the oem tail pipes?
Yes. I can post a pic or two when I get home (out now). Given the factory tips will work on the 1FG config, I'd assume any tip that works in place of factory tips will work with the AWE system and vice versa.
Raptor911
Raptor911
Ashburn, VA
To be clear, I am not talking about the tips. I am talking about the entire tail pipe section from where it attaches to the muffler all the way to the tips.
Again I want to use the 1fg with the corsa tail pipe section.
My worry is the corsa tail pipes will not bolt up to the 1fg at the muffler section.
Stroked out
Florida
If your corsa tailpipes work with corsa 14398 muffler then 0fg should work as both were designed to work with factory components.
