Aux 4 to RSC/ABS
Rookie
Fort Wayne, IN
I keep learning all sorts of shit ford jacked up in the 13. First I find out I don't have a DVD player. Not that I'd ever use it but it's the principle that matters and now I learn I can't do a burnout. This is horseshit.
Basically, this mod would allow you to disable these "safety features" along with abs via the aux switch so you can "play" when you feel like it?...
RLTW
TX
That's the idea, DVD player shmeVD player, they got enough right that it's worth it.
The Car Stereo Company
here, on frf
a standard automotive relay will work like this. these are rated at 30 amp.
here, on frf
the two terminals that have the connectors are normally closed internally. connect the ends to the (cut) wire for the abs.
RLTW
TX
So the top picture is where you'd insert into the fuse box right? or am i con-fused lol. the bottom picture is where you attach your abs wires? So how do you control the activation/deactivation of the abs? Sorry I'm terrible with wiring.
here, on frf
the two that have the blue connectors needs to interrupt the abs wire. ( doesnt matter which one as long as they are connected there) connect either the left or the right (again, doesnt matter) to ground and the opposite to power (aux switch wire that has power when flipped on) the top post is not used
RLTW
TX
Got it, Thanks NOS! Now someone just needs to do it. Exciting.
RLTW
TX
My truck is -3 days old, lol. Would love to do some testing, alas i've got a little wait yet.
