Jeff Drewett
Hoping you guys can help me with a 2020 Raptor aux switch issue. I suddenly lost functionality of several aftermarket accessories I had wired into the upfitter aux switches or battery power directly. I opened the hood and found the mess in the pic thanks to a squirrel (which I have seen come out from under my hood but have yet to exterminate ).
I’m in the process of rewiring everything but I have an issue with the Aux 4 switch not delivering power. The 10A fuse #80 is good but there is no 12vdc on either fuse post. The book calls this “Upfitter 4 Relay” so I am assuming the switch is actually only powering a relay but I can’t find where this relay is located. Anyone know? The other aux switches are all working. Any help or suggestions of things to look at, I’ll gladly try! I searched around the forum but haven‘t found anything regarding the relays. Thanks in advance!!
