Auto Temp for heated / cooled seats?
cfmistry
Maryland
Not sure if I remember seeing this before I re-coded for the HSW. Does this show up on stock trucks? And what the heck is it?
Antho
@cfmistry What triggered it? Did you hit the headed seat button? You may have enabled it accidentally in the APIM. If you hit the heated seat button it should show you what bar it is set to. Not really necessary if you have the hard buttons on the bottom that indicate the setting.
C
cfmistry
Maryland
Yeah that prompt comes up from hitting the button, I have just never seen that text before. I'm guessing I messed something up in the APIM programming.
Antho
@cfmistry Probably. I would look at 7D0-02-02. Should be 0xxx-xxxx-xx— If you have something else you may have mistakenly enabled it. Of course thats if it bothers you.
