- Joined
- Dec 16, 2016
- Posts
- 17,942
- Reaction score
- 27,903
No apologies; it’s your truck !
I still think you need more sub.
First off, I'm not trying to build the best system possible. I mostly just want a good system with clarity. The stock system does come off as rather flat to me. I do want some bass, but I don't need to a ton of it. Mostly listen to rock and country. I've seen the under $500 thread and like the idea, but am a little afraid it's not going to be satisfying long term and I'll end up doing a second upgrade.
active means the amp is doing the crossover work. Sounds like this is how they are wiring you up. 7-8 channels
2 channels to front tweeters
2 channels to front mid woofers
2 channels to rear coax
2 channels bridged to 1 for sub
To me that is overkill. Here is how I would do it. with a 5-6 channel amp.
2 channels to front passive crossover to tweeters and mid woofers
2 channels bridged to 1 for subs
in theory, you gain a little more efficiency because you are not having to scrub frequency or power by going through a passive crossover (capacitors and coils). In most cases, it is not needed. one benefit is you are able to adjust the crossover point between the speakers to address any issue.
As we said before...your stated goals of a nice sounding truck without breaking the bank do not line up with the system you were quoted. Dedicated active crossovers for separates is pretty high end stuff. And Rock and country will sound flat with just a single 8 at moderate volumes with the high end components and power you have.
Why so hell bent on Audison? plenty of other amps out there. Paying labor....to do a system that you said you wanted, you should come in around $3k, and that would include 2 10's, no a single 8.
It sounds like a lot, but, if you were of a mind to do it in stages, you could do the sub first on the ’17 without a DSP. The add in the rest of the stuff. The 18 and up I think requires the DSP(?) because of the b&o system differences.
My build consists of basically the same door speakers as yours. Only difference is I am running 2 10”subs. I will be using Arc Audio 1200.6 for the mids/highs and Arc Audio 1100.1 to run the 2 subs. Mosconi 6-8 for the processor. If your willing to wait a month I can give you feedback on subs however after all the discussions/reviews think for the money the Audiomobile subs will be the best bang for the buck (by far)for what I am trying to accomplish. Like you, I want clarity and accurate. I am not trying to be heard miles away. Also, in what I have seen, the install and tuning is just as if not more important then the gear. So yes, one mono amp will run 2 subs.A few things.
I'm not hellbent on audison, it's just what my shop is pushing. Agree that I probably need to look strongly at other DSP/amp options, on my own and/or with another shop.
The conversation above does help clear things up a bit. Looking at the audison site, and based on what @The Car Stereo Company stated above, I'm pretty confident the plan was to use amp with seperate channels for the front components, ditching the crossover that came with the focals. I can see where that's advantagous from a DSP standpoint. With this amp, I'd get 85W @ 4ohm for the main 6 speakers, and 1 260W @ 4ohm for a single sub. Sounds like 85W is more than enough, but I'm limited on the sub side. I could add a seperate amp for the subs, but then my 'main' sub is over sized.
The pre-configured setup, which I imagine can be tweaked.
High pass (tweeters) - 3000hz@12db
Band pass (front woofers) - 500-3000hz@12db
High pass (rear) - 80hz@12db
Lo pass (Sub) - 80hz@12db
But again, I think it's time to look at other options a bit further.
One question, can a single mono amp be used to drive 2 subs? My understanding is that if you wire 2 speakers in parallel like this, you're presenting the impedance of the speakers on the amp. So for example, a mono amp that was rated to handle a 4ohm or 2 ohm impedance hooked up to two subs rated at 4 ohms, would actually have the W specified for 2 ohms. Correct?
