Are Ko2 37's with stock fenders, 2" lift, mid perch possible?
CruizRaptor
Hey everyone, My raptor goes in tomorrow to have the 2" leveling kit installed and to finally get rid of that horrible stock look. Is it possible to run Ko2 37's with the leveling kit and stock fenders, without other modifications? Currently my Raptor does minimal off road adventures and I don't expect to be catching any air in the future. Any thoughts and advise is appreciated.
As a side question, with 2" leveling being installed, is it standard for the shocks to be adjusted to mid perch or are they left at the lowest perch with the 2" leveling kit? Is their a standard leveling kit that Ford would install? I havent inquired about specifix with the kit... My truck will be going to a local Ford dealership that doesn't deal with Raptors all that much and I just want to be sure that the leveling kit is done right the first time... Thanks again!
Sent from my SM-G900V using Tapatalk
Bulletnjm
New Jersey
Leveling kits are a big no no for raptors. I would suggest just mid perch. You will rub and will need to trim slightly
Deleted member 12951
Guest
:popcorn:
But seriously, even Bulletnjm the mall crawler knows that a lift is not the answer, listen to him. There is better ways to accomplish your goals. And go on a raptor run, you will be hooked and want to do more off-roading and get some air while you are at it
Bulletnjm
New Jersey
:popcorn:
I may not use my truck to its full potential but I know it damn well.
whoisbigman
Palm Beach Florida
I have 37 Nitto's on mid perch and stock rims and have never rubbed anywhere. That being said... i would put 35's on if i was going to go offroading in any serious way. I am just as sure that if I really wanted to, I could make them rub. Do a mid perch, skip the lift kit.
Zeus
Upstate SC
Stock beadlocks and BFGs will touch the fender liner when jumping, and this is on mid perch. I haven't tried it but I'm sure a 37 would jam the fender pretty good. You may not plan on catching air, but I'd hate to be precluded from doing so and constantly worrying about it.
2014RubyRed
Galesburg, IL
@Madcowranch has 3.0's with Methods and 37" KO's. He's ******* nuts and hasn't punched out a liner with stock fenders yet. Hit him up and ask some questions because he's got the setup you need.
Good luck!!!
