Anyone try the AirLyft air bags?
dfw62
MA and FL
That is great information and thanks for the pictures. Just so I understand you use a bike pump with the trailer attached and it will lift the truck? The Air lift rep told a different story although is second hand information. Thanks for all the information!
Yes a bike pump easily fills the bags as the max air pressure is only 35 psi. With the trailer on the truck and the WD hitch engaged there is still sag (bags show 7 psi) and pumping up the bags to 27 psi raises the rear and eliminates the sag.
What the Air Lift rep said makes no sense to me. If the bags put pressure on the coils to keep them from compressing to eliminate sag the truck would ride extremely rough as this would imply the coils would not be allowed to compress. It would also imply that once the suspension cycled (coils compressed) the bags would try to hold the coils in a compressed state which would result in sag and continued rough ride. It seems to me that the bags act in two ways; one to provide lift to eliminate sag and two to provide some degree of friction within the coils to stiffen the suspension. That's my 2 cents anyway.
edwinprieto89
florida
What system do you use, the one with red bags inside the spiral?
dfw62
MA and FL
Yes the red bag within the coils rated for 1000 pounds.
On a side note, I now inflate to 27 psi before hooking up the trailer based on info provided by others that it is recommended to pre-inflate before loading per Airlift. However, I've noticed no benefit over hooking up before inflating to 27 psi.
LUCERO
PORTALES NEW MEXICO
I am considering a Gen 3 but worried about towing roughly 7500# boat so considering the Air Lift. Spoke with local shop and they happen to have the rep from Air Lyft in shop later in the week. Anyway rep said bags inflated prior to load as they increase resistance of springs to decrease squat. They do not provide direct vertical lift.....curious those who have installed is this the case? Thanks so much
AaronCarl
west virginia
Yes I have them on my 2020 and they work they bring it back to normal height it I feel they limit the travel of the factory suspension I am looking for another option
Ox3721
Arizona
News from SEMA - Airlift will be releasing a 5000 kit for the Gen 3 Raptors. ETA possibly by the end of the year. There’s a post with video on the Gen 3 Raptor Facebook.
munch520
Midwest
Can't wait til these drop!
