Anyone run a quick disconnect sway bar end link?
FishFreak
Sacramento, CA
Does anyone run a quick disconnect sway bar end link? If so can you share your setup and how you use it? Can you leave one end connected and the other disconnected off-road without problems?
My new-to-me 2014 SE was setup with no sway bar, and I can see why, it articulates so well without it, however, I'd like to run it on the street.
dinocrisis
Southern California
I didn't run a sway bar on my Gen 2. Just don’t hit corners like a sports car and you'll be fine. After a couple of weeks you even forget that you do not have one.
Yes, I removed mine weeks ago because of a faulty/clunky end link. Felt sloppy and Nex made fun of me for wanting to throw it back on but after weeks of not having it, I’m now used to it and don’t listen to him I still apex every corner.
GCATX
King Dingaling
Central Texas
Yikes. I wouldn't remove mine, they get pretty squirely doing emergency maneuvers at highway speed, with the bar connected.
The broke dikk way to achieve what you want is to undo a bolt at one side and you will get the same thing. You can zip tie up the loose arm.
Space Ghost
FL
hows driving long trips on hwy without one?
Old ass expedition i had the rubber on the endlinks eroded and it needed constant steering input and the lightest touch would send it half a lane over.
CleverGirl_
Cabin Clown
It’s not that bad. I’ve had mine off and driven left and right I40 among the worst drivers on the road.
