Anyone mount a Badland jack to SVC chase/bypass rack?
8250_RPM
Just curious if anyone has done this? SVC’s rack is ready for the Pro Eagle, but I’m curious if anyone has modified the rack or jack itself to work with the Badland?
8250_RPM
I may have figured out the answer to my own question…the jack is strapped to a tray that is actually mounted to the rack itself. Only thing I need to find is a tray for the Badland and verify if the width of the tray/jack is wider than that of the Pro Eagle. The jack itself is a tight fit between two 37” KM3 tires.
Hard R
California
I use one of these.
HORN HIGH ACES
Colorado
I use one of these.
Where did you get the caps that cover the bed bolt locations?
8250_RPM
Thanks for the recommendation. I actually found Grove Fabworks immediately after posting and confirmed just now that they can modify the mount to essentially replicate the Pro Eagle so I can fasten directly to the SVC rack without any further drilling.
