Any of you guys tow a trailer?
t_j
Chicago, IL
t_j & rsike - Thanks for the replies, I really appreciate it. :)
Did either of you guys need to run an "extreme" drop hitch to keep the trailer level or would my existing 2" drop hitch work OK (running the factory suspension here) ? Thx again!
The standard 2" drop on my wd hitch was not enough to level the trailer ended up getting 4-10" drop bar and trimming off the bottom after getting the right height set.
Luke13
Norco, Ca
Rptr, did I read you right? You said you have 40" tires on your raptor with a 6" drop hitch? I guess I'm confused as to how this is possible on a raptor. A f250 this is the norm.
rptr
+5 fenders, King 3.0 2 inches above top perch, RCV axles, sypdertrax unit bearings/hubs, Dynatrac pro 60 IFS with front detroit locker. 5.13 gears.
rptr
Holy shit, got any pics
trucks in the shop till tomorrow getting the brand new fenders and some other goodies including transfer case and satin black wrap.
heres a older pic. same setup-ish. Im in the united states right now no computer only pic i have. once i get back to Canada i will post many pics of my new setup for yall.
rsike
Tempe AZ / New Caledonia
I don't remember what the drop of the hitch is but it was not extreme I think 3" (I'm out of the country so I can't check). All I did was measure the height of the receiver and of the trailer when level and used the difference for the drop. Don't know if that was the right way to do it but it seems to work fine. My lights are setting a tad bit high with the trailer so I might need to make an adjustment. I'm on mid perch so that probably does not help the lights.
rptr
Towin this tonite from houston to northern ontario. 2000 plus miles! Its a piece of cake for the raptor!
CNAIMO
Central Mass
32 foot 8313 Rockwood RV
I tow a 32 ft 8313 Rockwood RV and use a Equalizer Hitch .. approx 7500lbs
Fastcote
Powell, OH
Towed a 34 footer for a friend a couple hundred miles. I have Deaver +3 and the SVC adjustable bumps. With the +3 Deavers the bumps sit pretty high above the strike plate at rest. No clue how close they came while driving but hauling was a breeze. 70+ mph the while way.
