aj.cruz
Does anyone know where I can find info on replacing the heater core on a 2013 Raptor?
I can't find anything on FRF or the Googles.
My truck started overheating today and is burning through coolant pretty quickly.
Smells like coolant in the cab, I can see steam coming through the cab's vents, and the underside of the passenger dash is wet.
At idle I'm leaking water under the truck @ about mid-cab. It looks like insulation from the firewall continues underneath above the exhaust heat shield to about mid-cab. I can see the insulation is saturated with water and dripping down onto the heat shield and rolling off onto the ground.
Thanks.
Thanks.
