TuckerTravis
Yeah turns out my whole base and antenna were f'd from the get go. Got dealer to order whole new kit. I just hope my stubby picks up my stations. Looks like my truck stays on driveway for now.
Good Morning,
Two things come to mind
1) Why not try and find an electric antanna. Assuming you can find a black electirc It should turn on and off with the radio.
antanna and opening up the hole in the base to be large enough to allow the electric antanna to come through. As I recall you can set the highth you want the antanna to go up to. To make it look factory you need to use the stock base.
The only other part of this that I see is being able to seal the open from the eleaments.
Shouldn't be to much trouble as there are different gorment that will work,
2) Remove and replace the stubby antanna to the middle rear of the roof.
Of course that would require some body shop time. While your at it, Move the sirrus
antanna to the meddle rear like wise. With a lilltle imaginanItion you could set it up
to look very cool.
My body shop told me to move the sirrus antanna to the raar would require extended
cables and than the making an reshooting the entire roof. I also go's with out saying that the passinger side fender would require some body work as well. I see the work
comming in at just under 1k to do the job right. Paint matching etc.
JMHO, one other thing in 2013 ford is releasing a HD radio, I am not sure as standard
or optional equipment. Certainly with a stubby on the roof you would not have a hight
issue. Your call.
I am in the planning stages now. It won't be an easy job but it can be done.
As to CB antanna's on the roof, it is pretty much the same thing.
I am not sure what they were using for radio, be it CB with and amplfier or a UHF/VHF. radio. The long range two ways that are on the FRS are exempt from regulation. I do know the Mexican Goverment does not like the use of any two way communication equipment with out there permission. Same here in the USA as to
UHF/VHF premits and of course there is Ham Radio as well, which does require a licence
for use. As to weither or not the FCC has the resources to police this sort of activity. I am not sure how the Canada Goverment looks at this sort of activity, if it requires a permit will,
I would just get the premits. The Ham you will need to study for.
Stay Safe
Rusty
I told you my spelling was not at is's best.
