GvegasRaptor
Thanks I have alot of Advanced in my area. I will stop by their tomorrow
AutoZone- "Raptor" brand adjustable antenna! Matches VHF antennas pretty well
I like that. You can probably adjust the height to barely above cabin height so you can still use it as a parking garage guide.
i dont like the lump in the middle
if you cut your antenna, make sure to do it in 3in increments until you get to the desired length. antennas are 31 inches for a reason, so just any random cut can possibly diminish your reception
a standard 31in antenna is 1/4 of a wavelength at 1 watt. since the frequency band is from 87.7 to 107.9 (in the U.S.) taking 3inches at a time helps keep the wavelength to height ratio intact to retain the best possible reception. that is until it is to low to have a proper ground plane at which point reception will be terrible.31 is not an increment of 3 just fyi
thats the one in yur pic? cool. think ill go with that one. looks good and priced right. 'preciate it.Found the part # on the advanced auto website.
Buy Metra 17" Fiberglass Mast CF-RMF2 at Advance Auto Parts
