mashtastic
Should connects right behind the glove box. Utube has vids
Yes just received the part. Base of the antenna and the cable is 1 piece.should be the base plus a short length of cable. there should be a connection at the passenger footwell area for the cable. you will need to run the cable and gromet through the body. best to pull the render liner off. you will have easy access
yes the plastic linerYes just received the part. Base of the antenna and the cable is 1 piece.
Is it fairly easy to remove the passenger side fender liner? are you talking about the wheel liner?
