Another Brake Pedal/Windshield Wiper Question
BIRDMAN
Birdministrator
Boston
My bet is that it is not a pulse in brake pressure but a vibration felt in the pedal. The wiper motor and pedal assembly are both mounted to the cowl/firewall. As the wipers move back and forth you feel the pulse/vibration from the wiper motor in the pedal.
as a matter of fact i was just about to post the same thing cause it is raining today and i paid attention- all i felt was some vibration from the wipers. hell, the whole truck rocks side to side with the motion of the wipers so i can deal with a little pedal vibration. pulsating pedal is something entirely different.
whtrapta
Ostrich Wrangler
Bolivar/Springfield, MO
I have this issue, well not really issue, but this too. Its kinda strange the first time I felt it. It doesn't really bother me that much anymore though.
champcaracing
how about its raining, wipers are on. then you hit the brake pedal. bet its the abs kicking in. freaked the hell out my girlfriend when she had it for 3 weeks. ok it was snow due to where i live but wet pavement is wet pavement. just a thought???
IRONMAN
Well-Known Member
MICHIGAN
I'll be sitting at a light waiting, with the wipers going and I'll feel the pulse every time they wipe.
JP7
Likes Canadian Mudbaths
Calgary, Alberta
I use offroad mode. I don't need brakes.
Never noticed any bad vibes from the brakes at all with wipers on - but I use RainX so a lot of the time I don't need wipers.
jdowens1
Ford Senior Master Technician
Montana
I think you should change your blinker fluid and check your Panooter valve!
jdowens1
Montana
I would agree with power fluctuations and also agree with the fact they are bolted in a pretty close together. If anyone ever pushes on a clutch, brake pedal or anything of the sort you can see your firewall flexing. Your wiper motor has got some torque behind it each time it turns on the torque itself would be enough to flex the firewall and be able to resonate through the brake pedal.
whisler151
Dallas, TX
Good. I was going to ask you all if this was normal. Not that its a big deal, just a bit annoying.
I figured they mounted the wiper motor on top of the break pedal or something like that.
95,404
58,973
Kwazyace
