Amber Lights During the Day
Russ103
MD
I used the lowest tech way possible. I put electrical tape over my light sensor so my lights (including the HVAC/radio buttons) are lit up all the time. I hate auto lights, so having everything on like a motorcycle is my preference.
Angry_Pu
Sweden
I downloaded my " As built module data" from Ford Service Info (https://www.motorcraftservice.com/AsBuilt)
Enter your VIN then security characters and Submit.
Wait a little for the screen to update with your info.
I saved the screen shot with all the original as built settings to pdf and the downloaded ".ab" file to my Raptor folder on my PC.
Not sure how to use that ".ab" file yet but I have a copy for now.
As was also recommended, I also have a printed copy in a paper Raptor file with the Forscan info.
that does not aply fir europe
Angry_Pu
Sweden
Did you change 726-29-02 DRL - Position Lamp Cfg at all?
My truck is I believe "DRL - Parking Lights & Low Beams only" as I am not using the turn signals. Maybe try that one to get almost there to see if it works.
i did. nothing helps. amber still off. any more ideas?
beskarraptor
oklahoma
Yes, you can use Forscan to have the amber markers as the DRL, either with or without the headlights on. Better to view it on the spreadsheet (less confusing): https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466
Anyway, the relevant portion of the spreadsheet with the various options is pasted below.
DRL - Parking Lights only (stock LEDs only)
BCM
726-26-02 x1xx xxxx xxxx
726-50-01 01xx
** Testing DRLs: Make sure all of the following are set: **
1. Daytime Lights box checked in cluster under settings, adv settings, vehicle, lighting
2. Headlamp switch in the Auto position
3. Truck must be in gear for DRLs to work
DRL - Parking Light only (Halogens)
BCM
726-45-01 xxxx 7Fxx xxxx
726-50-01 108E
BCM
726-50-01 02xx
DRL - Parking Lights & Turns only
BCM
726-50-01 08xx
DRL - Anzo switchback white halo
BCM
726-50-01 10xx
DRL - Turns only (Halogen/aftermarket lights only)
BCM
** On stock LEDs this will also illuminate outer halo
726-50-01 08xx
Dumb question incoming. I just bought my 2019 801 a few days ago. How does one obtain/operate forscan?
sbradle4
knoxville, TN
I looked into this, but don’t want the taillights to be on with the amber outline and three grille markers. Don’t think there is a way for no parking taillights.
95,462
59,070
Asqrd
