Amber lights and Forscan
jikjak
Canada
looks like i just need to buy that cable and download the forscan program on my laptop.
will it work with a macbook pro?
wreedsvt
Yuma, AZ
You must run Windows. You can install a VM on your MacBook and run Windows to allow Forscan to work.
KryptosXLayer2
Charlotte, NC, USA
I have and its working as expected.
The codes I have used are
BCM 726-26-02 x1xx xxxx xxxx
726-50-01 01xx
I used Forscan to set my DRL's to be Marker Lights + Turn Signals. Works like a champ and turn signals function normally.
Did either of you use the first code listed for Marker Lights + Turn Signals?
Code:
726-45-01	xxxx	7Fxx	xxxx
It has that one as the first of three, and im33303 just gave the last two only.
im33303
Code:
Yes on that too. I might just have forgot that third code too.
Here are the codes again for Parking Lights & Turn Only
BCM 726-45-01 xxxx 7Fxx xxxx
726-50-01 08xx
Schmagagled
726-50-01 01xx
Here is a picture
I did the same thing, FORSCAN says that's the setting for "parking Lights" but on our Raptors the markers come on with that setting as well.
That's fine with me but when I first tried settings based on a suggestion from Livnitup over on the F-150 site I ended up with markers and turns and no halos. He doesn't have a Raptor so he was basing his suggestion on what he knew at the time.
So I reset everything (light settings) and changed the DRL setting for parking lights only and voila; Markers and Halos only.
I'll betcha that the markers have their own setting in the BCM but we just haven't dug that far into it to figure out what it is. I stopped at markers and halos because that's what I was looking for in the first place.
S.
nikhsub1
Los Angeles
726-50-01 08xx
I've got a 2018 and none of these codes are doing it for me... any suggestions?
---------- Post added at 10:53 AM ---------- Previous post was at 10:43 AM ----------
Sorry I get ******* award... car has to be in gear... anyway, it's working but with the turn signals as well, any way to just get the halos without the turn signals? TIA.
