I built a sliding kitchen ... it is about 300 pounds, in order to support the extra load, added both 3/4" spacer and airlift airbags (15 PSI), and it works perfect for me, for sure once I will be able to lift springs with 250+ I will do. btw I also calibrate the new high using forscanIs anyone running a GFC and decked/similar drawer system. I’m guessing spacers/ upgraded rear coils would be needed.
Do you know what the part number is for your air bag kit?I built a sliding kitchen ... it is about 300 pounds, in order to support the extra load, added both 3/4" spacer and airlift airbags (15 PSI), and it works perfect for me, for sure once I will be able to lift springs with 250+ I will do. btw I also calibrate the new high using forscan
sure, I tried 2 kits until I found the perfect one for me, in airlift you have a calculator that you can provide dimensions and get part#, but anyway I'm using the biggest they producing...Do you know what the part number is for your air bag kit?
Still, I'm waiting for eibach to release the kit , front and rear with lift and +250 pound ...Thank you for the information! I appreciate your R&D time!
