??? Alignment - Tires ???
castine917
Caledonia, Mi.
Truck was checked and they said "all is OK, you need only alignment".
Here are the pictures/information I mentioned before:
1. Alignment - Before/After
2. Front right tire showing the outside part of tire much more worn vs. the inner part. Tire is less about 5000 miles. Left side tire is great.
My question now is this (following this last alignment):
How will the right front tire wear after alignment being done? Do I have to turn the tire with the worn out side be in the inside? I am afraid that in about 2000 miles it will not pass inspection.
ANY and ALL suggestions will HELP !
Did you rotate tires also?
