alcoolaid's 2017 Raptor - Weekend Warrior
alcoolaid
alcoolaid
Vancouver, BC
Been raining a lot in Vancouver recently and had to travel for work so there wasn't a lot of updating to do but got some more stuff done!
S2 Pro - > Squadron Pro Driving Combo -> Squadron Pro Spot
Got my @BuiltRight side panels installed
Stuck on some of the @BuiltRight velcro panels. Will fill these up later.
The start of the dual battery wiring...
Got some 2 awg wire, 2 awg 3/8" lugs and 2 awg 1/4" lugs. Help to have the right tools!
This is where I chose to ground my second battery
The worst/hardest part of the job.. feeding wire through the damn firewall grommet
Just enough space for some 2 awg wire
Some anderson connectors for quick removal of the battery setup when required
alcoolaid
alcoolaid
Vancouver, BC
Bracket for Blue Sea ML-ACR and 150A breaker. I just drilled 4 holes through the bracket and battery box and used 1/4" hardware to secure it. Solid enough for what its doing.
Everything bolted on
All wired up. Also pictured is @SDHQ Switch Pros SP-9100 mount.
Gonna test out this 30" rear chase light bar from amazon. $90! Tent blocks the 3rd brake light so I thought this would help visibility.
Modifying the battery box
Installed with ML-ACR remote switch
Slowly buttoning everything up over time. Won't finalize the wiring for the SP9100 outputs until I get my S1 reverse light kit and a-pillar mount lights in.
Change in topic, made a mount for my waterport
It flexed the side rails when full of water so I came up with a cheap solution that works better that I could have imagined lol
Feeling overland as f**k!
11lb propane tank mounted with quick fist XL
Axe and poop shovel mounted. Waiting on 3" quick fists for fire extinguisher
Evan B
Salinas
+1 following. Great thread and great build! Just got a 2020 SCREW. Getting the Pace-Edwards full electric with rack options installed in a week. I’m glad I went with that looking at your build. Keep up the post!!
