GEN 2 Air bags for towing??
Big-Foot
Kenyon, MN / Gold Canyon, AZ
Anyone try timbrens yet...install them when towing then take them out when not...seams like a simple solution?
I just got an email back from Timbren and they have not got anything for e G2 Raptor in the Timbren SES line. I have asked them when they anticipate having something for the market and will let you know what they say.
DrifterGTR
South Carolina
Admittedly I'm not the most tow crazy or informed person when it comes to suspension. But, could you just increase the length of the overload bump stops and slightly increase the towing capacity?
O
OPT PRIME
Decided I am not changing a thing, no bags, no leveling hitch, nope! I just moved the crawler back alittle on the trailer. Alittle sag but no big deal!
You don't think 1,000 pounds back there vs the rated 600 would deform the springs do you?
FatBuoy
Hmmmm. Interesting. I had never heard of these. It sounds like you could install these, and just remove quickly when taking offroad. Or, if you are offroad more than you tow, vice-versa. Installation time is 45 minutes, but I'm assuming once you've done it the first time, swapping back and forth would be quicker.
Anyone else have experience with these? Good? Bad?
Digger
Oxford, Ma
Here's my truck and trailer without the weight distribution hitch. It sags at least 2" which was unacceptable with me.
tightt
Northern, NJ
I pull my 24' aluminum enclosed trailer to the MX races almost every weekend and it pulls the trailer effortlessly but squatted a little more than I'd like so I got weight distribution hitch and problem solved. $209 done.
How was the installation? Did it help with the squatting?
Digger
Oxford, Ma
It's exactly what you need. Easy to build and use although it's pretty heavy. You can crank the truck up 3"-4" higher than it needs to be and set the chains and lower it back into place and it's level. It pulls the trailer much nicer too because it's not squatting and wallowing all over the place because of the newer soft rear springs on the Gen2's.
Jred2255
MN
Do you have a link for the one you bought?
