nikhsub1
Caliper covers on a Raptor, I've seen it all now
Offset? Weight? 18x9?
I need some help, I’m looking at 2 different wheels. One is a method 8.5 x 17 with 4.75 backspacing the other is KMC XD 9x17 with -12 mm offset. I’m going to use nitto ridge grappler tires 35 x 12.50 FYI.. how much farther will each of these stick out? I know I should be able to figure this out but I want to be sure on this before committing to buying. So plz help and thanks
I'll know weight when they arrive next week. 9.5 +12. So protrusion as Method.
---------- Post added at 07:45 AM ---------- Previous post was at 07:43 AM ----------
Method 1.3" further than stock
XD 2" further than stock (will require some trimming depending on front lift)
Thank You. If you can post the weight of them when they come in that would be great.
Will I be ok with the kmc hole shots -12 offset with 12.5 x35 nitto ridge grapplers with 2 inch lift in front ? I can do some beer and trimming if need
How wide are the wheels? Looks great btw
The Innov8's are 9" wide for beadlocks. 8.5 for non beadlock.
