Aftermarket Wheels
EricM
OHIO
They are not the same. Same Mhz but they are not compatible. Even those part numbers are different. One says 12 and one says 35. Everything I've read says they don't work. Would be nice if they did. Show me someone who got them to interchange either way.
Sitdown
Suburbia, IL
Re: TPMS sensors, I have come to the same conclusion that while 09-14 and 15+ may share the same frequency, they are not compatible (based on 15+ folks on f150forum). Possibly relating to 15+ trucks recording actual psi... vs idiot light below 38lbs on 2014 and earlier
I mistakenly put older style sensors in the set of wheels i just got for my '17 before learning of this. I planned to just see if i got lucky once bolted up ;)
@Addictive Desert Designs @ADDGrant , might you be able to confirm if Tire pressure readings worked when you bolted up those Fuels to your Gen2?
[EDIT - 12/16/2016]
2015-2017 TPMS PN Below (10-14 are not compatible):
Manufacturer: Ford
Part Number: F2GZ-1A189-A
Part: TIRE PRESSURE MONITORING SYSTEM SENSOR
Part Notes: MKX. 315mhz. 315 mhz.
Mesa, AZ
Not sure, we had them bolted up for like 20 mins for a photoshoot. Dont think they even had TPMS in them to begin with
Sitdown
Suburbia, IL
From at Friend at Ford
"The activation tool is different from the 2013 trucks to the 2017 trucks and the part number is not the same between trucks. A 9L3Z-1A189-A (315 MHZ) on the 2013 truck to a F2GZ-1A189-F (433 MHZ) on the 2017 Truck"
Pacific Wheel
Reno, NV
Part #mr31078516500. 17x8.5, 6x135, 0 offset, 4.75 backspacing. Don't want to list where I got them because I don't think they are a forum sponsor. PM me if you want to know where I ordered.
Have you actually received them yet? Method told us they wouldn't be arriving till late Jan early Feb
