Aftermarket wheel sizing questions.
FORDONLY
305 method double black will be going on mine ...not sure if I stick with stock tires or go to NITTOS ...
jikjak
Canada
The wheels I wanted to buy only come in 18x9 and they have a -1 offset.
Apparently that would mean they would stick out another 37mm vs the +30mm OEM wheel in the 37 package. That's almost 1.5 inches, I have a feeling they will rub.
btizzle
Gen3 raptor offsets are as follows:
Cast Aluminum: +1.3”/34mm
Forged Aluminum (bead lock): +1.3”/34mm
“Raptor 37” forged aluminum bead lock: +1.2”/30mm
anyone know the width of the cast aluminum gen 3 wheels?
looking at the method 701 bead grips, 17x8.5, with 0 offset. That will be 1.3 inches wider per side if the width of the method wheel is the same as the OEM cast aluminum..
sucks method doesn't have stock offset option.
Raptor911
Ashburn, VA
8.5" wide. very few aftermarket wheels will be stock offset
xlr8
Tejas
I prefer a +offset wheel to help from rocks and crap being thrown down the side of my truck. Aren't many options i know of, one from Method and a few from KMC but those are all i've researched. Most are zero offset and while they look pretty good definitely place the tire outside the fender more than i prefer.
