Aftermarket Carbon Fiber Package?
Jayrod
FL
All the Ford parts are readily available now except the door panels. This was my solution.
Talk to me about the door handles. What is that? Leather? Do you have a link to the CF parts for shifter and little accessory door?
marsh1
Talk to me about the door handles. What is that? Leather? Do you have a link to the CF parts for shiftier and little accessory door?
It's vinyl to match the seats. You have to cut the plastic weld on the panel then epoxy back on once covered. Here are the part numbers. Figure around $600 for all three. You have to shop around. The other piece that is not shown goes above the glove box.
Handle Assembly
Part Number: HL3Z-7213-HA
Panel - Instrument
Part Number: HL3Z-1504339-AC
Panel - Instrument
Part Number: HL3Z-1504608-AC
madrap
Handle Assembly
Panel - Instrument
Panel - Instrument
Easy to replace those three pieces ?
marsh1
The shifter and Sync cover are very easy to do. 15 minutes to do both
Found these instruction for Sync cover in another thread
Super easy. I just did mine.
1: open the center console
2: set EBrake and place shifter in N to give yourself some room infront
3 Starting from the rear (where the center console closes) pull up on the big piece of trim that surrounds the cupholders and gear shifter. Once the rear portion is popped up completely, pull rearward and remove the entire piece.
4: There are two Torx screws holding the sync door assembly in. Remove the two screws and carefully start to remove the assembly. You may have to remove the two additional torx screws between the shifter and cupholders and pop that panel up too to allow extra room.
5: There is a small switch and wire located on the rear portion of the sync door assembly that will prohibit you from removing it until you unclip the switch assembly. Just pop it off.
6: re assemble
