Macman
Here is a pic of mine mounted, similar to what ironman is selling:
Easy and quick.
![12111_10153761906085224_2006416010_n.jpg](/proxy.php?image=https%3A%2F%2Fscontent-b-ord.xx.fbcdn.net%2Fhphotos-prn1%2Ft1%2F12111_10153761906085224_2006416010_n.jpg&hash=71630c04ce689e4734bf5c361c31c7dd)
![1625500_10153761906170224_426543129_n.jpg](/proxy.php?image=https%3A%2F%2Ffbcdn-sphotos-b-a.akamaihd.net%2Fhphotos-ak-ash3%2Ft1%2F1625500_10153761906170224_426543129_n.jpg&hash=0d36af2bfb36a00cbb47e9af3b0e9dd6)
![1545709_10153761906275224_273149156_n.jpg](/proxy.php?image=https%3A%2F%2Fscontent-a-ord.xx.fbcdn.net%2Fhphotos-ash3%2Ft1%2F1545709_10153761906275224_273149156_n.jpg&hash=62012babe55a19d70af9e11c56523c2b)
![1653542_10153761906430224_2028463092_n.jpg](/proxy.php?image=https%3A%2F%2Ffbcdn-sphotos-c-a.akamaihd.net%2Fhphotos-ak-ash3%2F1653542_10153761906430224_2028463092_n.jpg&hash=e973bb67c267cee366b538ead921afe0)
![1546284_10153761906540224_854212230_n.jpg](/proxy.php?image=https%3A%2F%2Fscontent-a-ord.xx.fbcdn.net%2Fhphotos-prn2%2Ft1%2F1546284_10153761906540224_854212230_n.jpg&hash=cb13c662a5ad543a3228db06c7af3437)
Easy and quick.
You guys should modify the brackets to put the bar in line with the big gaps in the grill instead of through the mesh.
You get a lot more useable light from the bar. I found this out while making my own lights, I had the spacing wrong and they were about 1/2" too low and there was a pretty clear difference in the beam pattern on a wall I had the truck pointed at.
If you can get those apart easily, and the lens cover is just flat plastic, you can buy Optix or Lexan sheet from Home Depot and cut/break your own to have tinted ones. Optix gives better light transmission, but, is brittle more like glass(but still much stronger). Lexan is slightly less efficient at light transmission, but, is super durable and easier to work with. Important if you had to drill holes in it. If they don't have the proper thickness, you can order it from places online in whatever thickness you want and even in transparent colors(I saw red/blue/yellow/green) when I was looking.
Good to know. From what we've been told, SDHQ has two 40" bar brackets, one that centers like you said, and then one that is slightly higher for guys with winches.
