Adam's Polishes Detailing Guide
cbcgeneral
Southeast Pennsylvania
Hey @TheWolf the only thing I didn't see anything about was the glass sealant. I'm not sure if I missed it or not but it's definitely something that great for our trucks. It's helps out a ton when you're going through muddy water and it splashes and covers the entire windshield because it just slides right off rather than it sticking and not being able to see. It makes it a lot safer so you don't have to rush and try and turn on the wipers real fast. I use it on all my windows and it helps a bunch. Figured I'd mention it in case other members aren't familiar with the product. I even use it on my sunroof and it stops rain and water from leaving spots when it dries.
AdamsPolishes
AdamsPolishes
Yes! I will add the Glass Sealant now, thanks for noticing that.
-Dan
2014RubyRed
Galesburg, IL
@AdamsPolishes
Still looking for a solution remove was from plastic / rubber parts. Daughter went nuts with some wax a while back and I've tried everything to get it removed. Don't want to use something that will ruin the surface.
HELP!!!
Wilson
South Dakota
Did you try allperpose I like a tooth brush of some sort so agitate it, that should strip off any wax but will on the paint also.
---------- Post added at 10:06 AM ---------- Previous post was at 10:05 AM ----------
Always try a small spot un seen if posable first.
2014RubyRed
Galesburg, IL
Tried the All Purpose Cleaner yesterday with a soft brush. Got some of it off but not the really heavy places.
AdamsPolishes
AdamsPolishes
@AdamsPolishes
HELP!!!
Like @Wilson suggested, I first try All Purpose Cleaner. Use a microfiber towel on any smotth plastic or rubber. If the plastic is textured, then you have to use a small, stiff brush to get it out of the recesses in the plastic. Just tape off any adjacent painted surfaces so you don't scratch it with the brush.
If the APC does not work, then use Isopropyl Alcohol with the same techniques. If the wax residue is really old, you may have to soak it with the Isoproyl Alcohol, let it sit, then scrub, and repeat as needed.
Both APC and IPA will strip the wax or sealant off the paint, so you would need to reapply.
Another trick for wax residue for smooth plastic is a pencil eraser. Again, tape off any paint so you don't mar it with the eraser. I have not found the eraser to help on textured plastic, since the residue is down in the recesses of the texture.
-Dan
2014RubyRed
Galesburg, IL
Like @Wilson
If the APC does not work, then use Isopropyl Alcohol with the same techniques. If the wax residue is really old, you may have to soak it with the Isoproyl Alcohol, let it sit, then scrub, and repet as needed.
So the IPA will not make the plastic turn 'white'? This is mostly on the fenders of a Jeep and they are textured. Wouldn't want to damage those....
