GEN 2 Abrupt jerk after lifting off throttle
Alysium
California
Anyone experience a sharp and abrupt jerk after lifting off the throttle?
It feels like the truck just falls flat on its face or when you drop down several gears at high speed.
Happens after a few WOT runs and then lifting off the skinny pedal.
This has happened to my truck quite a few times already. Since then, I've had a tcm tune and drop and changed the transmission fluid/filter thinking this was transmission related.
Some basic info:
- Goosetuned, running e50
- Fresh ULV & filter, fluid level verified cold and hot.
- No other mechanical issues
- P05FF code, no other codes from forscan and scantool.
FordTechOne
Detroit
You may want to look closer at P05FF, was it set when you initially scanned it or did it only set after a self test on the PCM?
Alysium
Alysium
California
was already there when I did a scan a while back. that code doesn't have a lot of diagnostic info online.
it feels like the accelerator is functioning similiar to a momentary on/off switch. as soon as I lift off the accelerator, the truck feels like it hits a wall.
also performed a live monitor of the abs/wheel speed sensors and it was all normal, no signal dips or irregularities on the graphs.
(I bought oem front and rear spares due to a grunt noise I hear when I take a left at this street corner that has a drainage dip in it and anticipated there was an issue with the sensors.)
I do not have any sway bars so I know that that wasn't the cause of the noise.
FordTechOne
Detroit
P05FF is Brake Pressure Sensor/Brake Pedal Position Sensor Correlation. It sets when the PCM detects a mismatch between the brake pressure switch (BPS) and the brake pedal position (BPP) switch.
When the brake pedal input is unreliable (DTC set), the PCM can enter a fail safe mode due to the possibility of unintended acceleration caused by the driver pressing both the brake and accelerator at the same time. I would troubleshoot that DTC before going any further.
Alysium
Alysium
California
I replaced the brake position sensor a couple of months ago even though the sensor tested ok, maybe the replace the brake pressure sensor as well?
you recommend any other troubleshooting avenues to check out besides the ones I jave already done?
jrl2019R
Illinois
Some basic info:
Wow, just posted a new thread before I saw this. Take a look. Thanks
popcorn
Georgia
Bump, chasing the same issue. Also Goosetuned with TCM tune. Almost feels like some kind of convertor lockup just as I lift off throttle. Or possibly a BOV issue creating some type of engine brake.
