A/C Keeps Going Out
Jeff Henson
Atlanta, GA
Hi, I have a 2020 Raptor and my a/c seems to have a mind of its own. It works flawlessly most of the time but occasionally will just stop working for no rhyme or reason. It will usually start working again once I turn it off and let it sit for 30 minutes or so but I'm sick of riding around in this Georgia heat just waiting on the a/c to stop working. I've taken it in to two different dealerships and both claim to not be able to find any issues since it wasn't malfunctioning at the time that I took it in.
Anyone else out there with a similar problem? I can't be the only one with this issue. Thanks in advance for any help.
FordTechOne
Detroit
It sounds like the evaporator is icing up. TSB 22-2089 provides diagnostics to determine if the evaporator temperature sensor is biased and replace it if necessary.
