6.6L Stroker Extreme (11:1) from Livernois
SilentShooter
Siesta Key, FL
Hmm I was pretty close.
Fact is the 6.6l kit is really designed to handle High HP numbers and allows you to turn up the boost. I would say in a NA motor you might be able to get 50hp extra out of it if you run a high compression and e85. But I can not bring myself to spend that kind of money. Would be better off just replacing piston and rods, get the crank treated and be good to go at 1/4th the price.
GoMuscles
Houston
I knew there was a reason they wouldn't come right out and say what the numbers are.
