RICK ERICKSON
I recently got 2 6.2 low millage complete pull out core engines to performacne build. I was told one was a good runner and the other was a runner but had a light rod knock. Pulled both engins apart and they booth look to be in very good condition and can not see any reason for a rod, pin or maine knock. The only thing i found that might of caused a knock was one cam phaser I could rattel a little like the bolts that hold it onto the cam was lose but there not. The others felt solidly mounted on the cams. Is there a issue with the 6.2 cam phaser's ? Since i am performance building these for vintage cars I would like to use them but with a limited motion of about 8 degrees total for a wider tork curve
Here are the 2 car they are going into 50 Merc woody 60 T-bird
