50,000 Miles Service review
KentSD
www.BookBaja.com Baja yacht Support
San Diego
So hit the big 5-0 last week and took it in for service. Everything they said looked fine minus it looks like hell underneath but hey!
Ive hammered this truck as many of you know
Ive gone through
22 tires (37 BFG KO2)
4 sets of brakes
a few vacuum lines replaced
two melted oil pans
I would say about 35,000 miles total were in Baja with about 1/2 those miles been off road.
They said the fuel rod low pressures is due to driving it too fast for long periods of time. But okay it is what it is.
Im pretty sure any other truck would of caught on fire by now and burned to the ground.
So guess i got my monies worth. Going to give her another year of torture and then get another one.
FordPerf Addict
What oil did you put in this bad boy? And any trans or diff fluid changes ?
kboom
If you put that truck through that much abuse “fun” and it’s held up the way you mentioned, then it’s a true BEAST!
I’m quite pleased to see this review.
Pictures please!
What brand of tires did you go with?
Have you done any suspension mods?
Thanks!
KentSD
KentSD
San Diego
What lil did you put in this bad boy? And any trans or diff fluid changes ?
I changed the Tranny fluid at 25k even though they said do it at 50k i think. But when i did it at 25k they said it was fine.
---------- Post added at 06:47 PM ---------- Previous post was at 06:44 PM ----------
Pictures please!
Thanks!
Yeah true beast thats for sure. I wish the brake system was bigger. It gets so hot after long days im having to pump the brakes a lot. Definitely need to upgrade better then a dot3
I stick with BFG i like the softness of the tread but definitely chews up fast
Rear suspension upgraded with the Fox but the front stock is fine realistically
jabroni619
Kent, have you thought about looking into the new aluminum oil pan that the later 2018 builds come with?
