4wd Problem?
RaptorScrew
Oronoco, MN
Ok - I'll do my best to explain...
If running 4wd I hear a loud "CLICKING" noise in the front driver's side wheel hub when running 4wd.
The clicking noise is only there when engaged in 4wd.
First time noticing this noise was when I was trying to get out of a ditch. I was being pulled out and while accelerating during the extraction, the noise started.
Keith said (when he heard it for the first time: "That doesn't sound good") That's what I know. What could it be?
2011 SuperCrew 45k miles...
FordService
...If running 4wd I hear a loud "CLICKING" noise in the front driver's side wheel hub when running 4wd...
It sounds like a trip to the dealership is in your future, RaptorScrew. Let me know when you get a diagnosis and I'll be able to research ways to help, if needed.
Crystal
shooterAMG
Far northern Chicago suburbs
So the IWE uses what I would call a "helical" spring to stay engaged onto the hub splines. It's a relatively easy process to replace/inspect. If you're under warranty, it's a no brainer.
IMHO, I think IWE are getting blamed for times that the front wheels are bound up and the front diff finally gives up and allows a tire to slip, along with the popping sound.
I had the EXACT same thing happen during the SnoBall pre-run. I spent time and money to have it torn apart and replaced and saw no wear or issue only to have the exact same thing happen. That's why I think the behavior I'm seeing, and it looks like you may be as well, is actually the front diff slipping.
Check out the @BigJ post on a replacement Front Diff. Might give you some insight into how our open diff is supposed to work.
http://www.fordraptorforum.com/f5/my-take-wavetrac-differential-12856/
I will say, that popping is new and I don't like it, but it makes sense.
