4 more Aux. switches
Kmandoske
Bartlett, IL
I did a few illuminated panels. They came out good but were very difficult to make and make with high quality like I would want to buy. I had to stop making them. I can do the foot well lighting kit if your interested. The remote control head has to be seen. So you need to drill a small hole or do like most and leave both in your glove box. you only need the remote to change the color or pattern. Its kind of cool. I need to install in my truck soon.
scarrjack
scarrjack
The Park, Alberta
The illuminated panel is pretty sweet, looks like mine is a very limited edition then :happy107:
Kmandoske
Bartlett, IL
I kind of changed my mind. I may make a few more illuminated panels, they are a bitch to make and fragile when being installed as people try and push them into the head liner when they should not. If you want one let me know.
Ironhorse07
Central, MT
Looking at this picture it appears that a couple of wires, one of those the main ground, are riding hard on the stud for the main +12v. That definitely needs to be remedied. Maybe even put something over the stud like one of those rubber vacuum port caps.
scarrjack
scarrjack
The Park, Alberta
where exactly are you talking about? can you draw on the pic to show me where you are talking about
Ironhorse07
Central, MT
The wires are definitely up against that bolt but there is no movement of the wires to rub through the protective coating but I will look at putting a rubber cap on the cap for added protection
That is spot. 15 years as a helicopter mechanic gets me paranoid about that stuff. keep an eye on it.
