(4) 17x8.5 +0 6x135 (F-150) Raceline wheels and 37x12.50 BFG KM3 M/T tires
Cody Templeton
Des Moines, IA
Up for sale is a set of 4 Raceline wheels and BFG mud terrain tires. Wheels are Raceline Clutch 934 in matte black size 17x8.5 ET0 with bolt pattern 6x135 (6x5.5). Tires are BFG Mud Terrain T/A KM3 in size 37x12.50x17 load range D with speed rating 125Q M&S and 15/32" of tread depth remaining (new are 18/32"). Wheels are tires and perfectly balanced and have very little wear with no plugs or patches. These are by far the quietest and nicest riding M/T tire I've run. These do not include TPMS sensors, you will either need to swap yours onto them or purchase new ones and you will also need aftermarket lug nuts to fit (approximately 40 dollars for a set). These were used on a 13 Raptor at top perch front with a taller rear block and fit perfect. This setup new with mount and balance, fees, and tax is almost 3500 dollars. Looking for 2,250. Located in Des Moines, IA. Thanks!
C
Cody Templeton
Des Moines, IA
If you were closer to Dallas, TX Id ****** these up tomorrow. Good luck with the sale!
If I'm ever gonna be in the area with the truck I'll let ya know! I thought about shipping but most likely won't be worth it because they would probably have to go freight.
