You can't change the coil over perch height on a Gen II Raptor. Only the Gen 1 trucks have the ability to adjust the front coil overs by changing the perch location.
you can change the gen2 but getting a collar for them.
You are splitting hairs. Yes, you can raise the front end of a Gen II by using spacers, but you aren't changing the perch location on the shock body like you do on a Gen I.
yes, you adjust where the collar is. theres only one set ring. the collar on the gen2 are not fixed solid in place they can be moved.
