312 Method Wheels
Vegas_Sirk
Boise, ID
None are removable unless true beadlock. Black Rhino has the Dugger and Vision has the Nemesis. Vision is 18 and 20 only though
Some are as OMF sells replacement Beadlock rings for them:
EDIT: OMF lists only method standards and mesh. I was just hoping some of the new ones offered that as well.
Pacific Wheel
Reno, NV
Not technically a replacement. The mesh and standard don't come with rings to begin with. They can be added if you purchase the kit from OMF and add it to the Mesh or Standard. Here is how the wheel comes
Vegas_Sirk
Boise, ID
Ah that makes a lot more sense as on those older designs its just a bolt in the lip and they don't have the welded on fake beadlock. That's a bummer the 312 while having the look of a water draining beadlock don't actually have the holes. I have a set of 305 NV and I hate how they hold water so was hoping to run those OMF replacement rings.
Pacific Wheel
Reno, NV
The MR312 is an optical illusion. Looks like it has the same type of ring that would pool water but is actually has no pocket at all. Of course you can't remove it to paint it but water will not pool on the 312.
