30’ led
justvettn
GTA
The only stitch I consider with those top grill mounts is the air blockage and impact on cooling. I have no idea if it's enough to be relevant, and I'm not saying it is. Just food for thought.
I have asked that question before as it is a concern. I am also wondering about the horns, if they would need to be relocated. I think they would with the 40" not sure about the 30"
Yukon Joe
Trafford, PA
Looks great, I like the white over amber. Really stretches out the front grill.
Now get some retrofits from Ducati!
Joe
TOP OFF-ROAD
TOP OFF-ROAD
China
Nice work son! Looks good, nice and balanced with the two 30" lights. I wonder if it would be possible to mount two 40" lights. I have one mounted already and a second sitting in my garage would like to put it to good use.
Can a 30 '40' above 30 'below 40'
可以一个30’一个40’,上面30’下面40'的
MandR Automotive
The issue that we ran into was that the weight of the two light bars prevents the hood from unlatching. Thats why M&R recommends the 30" light bar above the ford sign using the grill support and the 40" below the ford sign since you will not be using the grill support frame for that model
Rapt
Dubai
I ve got a 40" on the top, wanted to fit another 40" amber on the bottom but was afraid of obstructing too much airflow to the radiator
justvettn
GTA
What did you mount it to and did you have to relocate your horns?
Rapt
Dubai
Customized some brackets and mounted it on some existing holes (no drilling), relocated horn and had to cut the inside of the grill so that it fits with the hood closed.
justvettn
GTA
Did you use the two big bolts to attach your custome breket and then the Rigid braket to that.
Some close up pictures of the mounting braket would be helpfull.
