MTF
Couldn't have been any good, a regular EB 3.5L is only good for 375 HP the Raptor Gen2's 3.5L is 450 HP.
Don’t you worry about me not having enough horse power. I will be tuning it with an hp tuner, cold air intake, no cats, after market cat back and probably a few turbo mods. 500 hp and 600ftlbs torque will not be a problem.Couldn't have been any good, a regular EB 3.5L is only good for 375 HP the Raptor Gen2's 3.5L is 450 HP.
I don't think this is a good idea, dollar wise.
Nothing is going to fit, a lot of modifications are going to be needed, frame rails, motor mounts and tranny mounts.
Electronics are not compatible, new PCM and BCM are going to be needed and who knows all the modules that would need to be swapped.
Gear shifter, steering wheel, Nav, info cluster, radio are not compatible with the 3.5L PCM and BCM
I do wish you a lot of luck though!!!
15 HP is not a lotOP has the 5.4L so the EB would have more power. Still may be a PITA but the 2012 had the EB so the swap should fit.
Sure I will give them a call tomorrow. Never hurts to talk to people who know some things.Robin, you should ask SDHQ for tips since they built the OG Eco Raptor.
