24 Raptor K&N Intake and CEL Code P2C90
Abiel_HTX
Houston TX
I recently installed a K&N Intake (mostly for sound) and got a CEL P2C90 code thrown at me.
raptor inake.jpgOnly researched ive seen was in Dodge vehicles. Anyone can help with this issue?
FordTechOne
Detroit
P2C90 sets when PCM detects the crankcase pressure sensor or crankcase ventilation hose is disconnected. Double check all of your connections; if it’s all connected properly you may want to call K&N to see if they’re aware of an issue.
A
Abiel_HTX
Houston TX
Yes i triple checked all connections and they are secured I will try to contact them to have more insight
Thank You
did you compare the number of connections stock vs. k&n?
also, check the connection points and the piping.
