24 R pre-delivery part collecting
cammac50
Lynn Haven, FL
Question on the door key lock issue. Why not just re-move the attachment rod from the door lock and change it to the blank plug? Trust to always have the charge in the battery to re-mote unlock, or even wire in a hidden power connect to the lock/unlock solenoid.
2024RaptorR_NOVA
2024RaptorR_NOVA
Nova Scotia
I think you may have replied in the wrong thread
2024RaptorR_NOVA
2024RaptorR_NOVA
Nova Scotia
i think hes saying if you delete the key lock cylinder rod you dont need jimmy jammers
Ohhhhh, if that’s the case he may have mistaken my list, I have “Jam Handles” which are used to close the doors without getting hand prints all over your glass/paint. I can’t stand greasy hand prints all over the paint after cleaning, especially on black vehicles.
cammac50
Lynn Haven, FL
Sorry, about that I thought it was blocking plate to prevent the EASY (less than 30 seconds) unlock from the exposed locking rod when you pry up the door handle. I will try to find a less focused group in here for this question. (I know it is the same for all F150 for a number of years and I believe even all the F series, SAD FORD hasn't corrected this)
2024RaptorR_NOVA
2024RaptorR_NOVA
Nova Scotia
Hmmmm very interesting, I have never heard of that. Can you send a link?
2024RaptorR_NOVA
2024RaptorR_NOVA
Nova Scotia
Here is the list for Baja
  • SVC Front and Rear Bumper -
  • ONX 30
  • 4 LP9s
  • Garmin Tread XL GPS, mount, harness
  • SDHQ Sunglass mount for Switch Pro
  • Switch Pro
  • SVC Heat Exchanger
  • McNeil Front Fenders +4
  • ARB wiring harness
  • Radio: Center console mount, radio, ICOM power cord, speaker.
  • 3rd brake light with Rigids and Antenna mount with cable
  • Front lower control arm pocket replacement
  • Front LC rear pivot reinforcement
  • Baja Designs S2 for bed corner mounted chase
  • Box/Reinforce Front Cross Member
  • SVC LCA
  • SVC UCA
  • SVC Upright
  • SVC Tie Rods
  • SVC Axles
  • SVC Shockmount
  • SVC Top-hat
  • Stainless Steel Brake Lines
  • Fox 2.5 Coil Overs
  • Fox 3.5 Bypass
  • Fox 3.5 Tube Piggyback Rear
  • Wheel Liners?
  • Rack: 5 Gallon, Jack, Power Tank
  • Bedside Supports
  • LCA Lock Outs
  • Rear Diff cover/gasket
  • Geiser Springs
  • Power tank
  • Pro eagle and mount
  • 5 gallon
  • ARB
  • Ford Performance Oil Separator
  • Innov8s
  • Foutz full skid
  • Starlink
Hahahahha you sponsoring me?
