2024 Upfitter Wiring - passthrough
ckelly33
ckelly33
The hot wires are the easiest to spot. One end of the passthrough wires are basically bundled under and behind them. Knowing that they HAD to be close to the hot wires (to tie them together) I finally found them by lowering my phone with video on down in that area and there they were.
As others have said, it would be WAY easier just to remove the battery
The other ends of the passthroughs are just as hard to spot. Remove the passenger side panel in front of the door down by the foot. You don't have to remove anything else but I had to lay on my back and look up in the hole to find them. At first I only saw one black capped wired but then I could find the rest.
All of these are bundled with tape and given the difficulty in visualization, it was was a little difficult to see where to cut the tape (I couldn't get my hand in a position to unwrap the tape ( other than the hot ones)
Good luck! Driving to the beach today with my freshly wired radar - already saved me a couple of times!
James O
Lubbock Texas 79407
I was looking for the pass through wires and located them and they seemed to be a little too short to work with. I then removed the lower carpet trim above foot well area and noticed the wires are tied up in a loop. If you cut the tape it will give you plenty of slack if anyone is needing to do this.
This is on my boring plain white 24 truck.
