- Joined
- Jan 29, 2012
- Posts
- 1,091
- Reaction score
- 590
Fits 2024 2025 Ford Raptor Gen 3 Refresh Modular Bumper ONLY.
This includes 37 and R package.
Introducing our new LED light bar-PRO wiTh a unique appearance and optimal performance.
- Curved LED light bar PRO
- Perfectly follows the Ford Raptor bumper and grille factory curvature
- Stays slim to the bumper for a sleek, built in look
- Don't need to remove grille or bumper
- No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
- Doesn't interfere with radiator air flow
DUAL COLOR
Main White LED Light with Amber DRL (daytime running lights)- White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
- Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic.
- Combo Pattern: combined spot and driving optics offers a balance between the distance and width
- Uses TIR (Total Internal Reflection) lens is different from our the regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
- Higher light efficiency: brighter, longer irradiation distance
- Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to prevent against UV, salt water, corrosion, fading and scratch resistant.
- Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
