2024 Ford F150 Raptor Generation 3 Reverse Light Kit Install | Full Install
MandR Automotive
⚒️⚒️Mike shows you step-by-step of powerful reverse light kit for the new 2024 Ford F150 Raptor Generation 3 (refresh). These 2 LED pods are hooked up to reverse AUX wires for an easy install. Follow this tutorial and install it yourself.
This in addition to factory reverse light. The factory reverse light doesn't provide enough light output at night. Install M&R reverse light with powerful white LED light that makes a huge difference. In addition you choose backlight of Red or Amber.
What You Get:
(2) two LED light pods
Spot Pattern, white LED light
6000K color temperature
LED: 2 x 10w, total 20watts
Up to 2,184 lumens each with total reverse kit up to 4,368 lumens
AMP at 12v: 1.65amps each LED pod
Each LED light pod is attached to a metal bracket on each side
Metal bracket is powder coated black
No cutting or drilling required. The kit is a complete bolt on
LED lenses-PRO series with a unique appearance and optimal performance.
Uses TIR (Total Internal Reflection) lens is different from the conventional optics parts, which lose some light internally and produce glare. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
Higher light efficiency: brighter, longer irradiation distance
Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to prevent against UV, salt water, corrosion, fading and scratch resistant.
Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
Combo Pattern: combined spot and driving optics offers a balance between the distance and width
Our light kits are for off-road use only.
All M&R Automotive light kits are for off road use only. Please enjoy them responsibility.
✌️Have an easy install & enjoy your next adventure brighter.
#ford #fordraptor ##fordperformance #fordf150raptor #4x4 #fordtrucks #truckmods #LightBarInstall #OffroadAdventure #DIYCarMods #OffroadLighting #AutomotiveInstallation #CarAccessories #MRAutomotive #CarDIYProjects #TruckMods #cars #CarMods #lightbar #CarProjects #autotech #trucks #superduty #newtrucks #offroadlife #truckmods #automotive #offroadadventures #LightBarInstall #ledlights #explorepage #installation #installs #MandRAutomotive #diyauto #customtrucks #autotech #carenthusiast #offroadlights #tutorial #howto #tutorial #rangerraptor #fordrangerraptor #raptorranger #nextgenrangerraptor #raptorrangers #rangerraptoroverland #fordraptorranger #rangerraptorclubph #fordtrucks #fordranger #4x4offroad #fordperformance #fordsofinstagram #offroadtrucks #fordraptor #4x4trucks #fordrangerforum #reverselight
