2023 New Raptor and Missing Options - Solved
BIGW0RM
Highest Access Member
Pirate
Jmeo
Massachusetts
Thank you. Do you know if i just need to the "ambient light (2)" part number and harness? Or will I need the cup holder assembly? Or both?
You will need the harness no matter what to get the cup holder lights working, John will help you with that. If you also want to add the media bin light and glovebox light you will only need (1) ambient light. If you want to add a light to the upper glovebox like I did, you will want (2). John will include a second harness for the addition of the lights if you want them, based on what lights you want to add.
Basically, one harness will run the cup holder lights and the other will add the media bin light and glovebox light (s). The are both plug and play harnesses. The only modding you will need to do is cutting holes for the media bin light (if yours doesn't have the knock out piece) and the upper glovebox (no knockout - have to make this hole).
BIGW0RM
Pirate
Thanks dude!
Swacer_2
PA
Was finally able to get my HVAC display installed by the dealer. Charged me a bit more than others have detailed here, but luckily was able to use some fordpass points from buying my wife's bronco.
The only disappointment I have is that i'm here a slight tapping behind the dash when everything gets warm. It sounds like 2 wirelooms bumping off each other.
ToadSmasher2K1
Home Is Where You Make It
KC
That would drive me nuts
ToadSmasher2K1
KC
I'm hoping it will settle with time, otherwise when I go in for an oil change, I'll have to have him look back into it again. Worst case, guess I'm going to be stuck pulling it apart myself. Its not great, but its too infrequent.
I’m easily triggered by the smallest of squeaks and rattles
Swacer_2
PA
Same here, but over the last couple of years I've calmed down on that. Its just not worth the stress to me. If the car runs, and everything in it runs, whatever lol
Bronco has rattles, GT350 has rattles, now raptor has rattles. All run, don't burn oil or parts, I'm satisfied lol
Ckhris
I just installed the motion sensors followed the instructions on forscan using other forum link… Ive used forscan before and got
the alarm on my display but never could get them to actually work yet… I went back into
forscan and set everything back to where it was for now… attempting to find another source for enabling these interior motion sensors.. if anyone has more info Im all ears
